Guest Andrew Report post Posted September 28, 2005 Yeah, i've got the 325i T/B aswell, the 320i rubber boot fitted onto the 325i T/B with a little work so no need to get a 325i one. This is definately a must for 320i owners. i'm fairly sure the dia. of the AFM is alot smaller also on 320s. Nope, the AFM's have the same diameter, just the boot on the 320i tapers down to a smaller diameter at the TB whereas the 325i doesn't taper, besides, it's not the AFM that's the bottle neck regardless if its the bottleneck - its still the most restrictive part of the whole system Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted September 28, 2005 Well got the 325i TB fitted, ground away and polished the intake entry to create a good match for the TB, also attacked the manifold with a rotary wire brush and a steel scowrer, came up like new worked a treat. So far cant tell if its faster, it revs quicker, feels smoother, not as congested when going at 40-60kmh, a little more responsive and its not running as rich. It does seem that the AFM produces a bottle neck that and/or the entry to the airbox/filter. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 28, 2005 Yip, it definately revs faster and feels smoother Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted September 28, 2005 Yep I reckon it is faster too, took it out on a familiar stretch of road and topped the usual speed by about 10kmh on a relativly short run. Not a particularly accurate test but satisfying all the same. :bounce: Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted September 28, 2005 putting my bigger one in didnt make a big difference, maybe seemed a little more torque and smoother, but otherwise relatively the same Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 8, 2005 Just a question regarding fuel economy, I have noticed my fuel consumption increase since changing the thottle body I used to average about 10l/100km. I think now its more like 10l/ 75-80km same kind of driving . What direction should I be looking in to fine tune the air fuel mixture and regain some economy? Custom chip/ ecu? Idle control valve? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 8, 2005 more power = less economy, when you trying to fool the stock ecu, there not much it can do Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 9, 2005 more power = less economy, when you trying to fool the stock ecu, there not much it can do Stop talking bullshit, more power does not always equal less economy Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 9, 2005 Thats what I thought, maybe is it possible to reach a compromise. I thought of maybe swapping the stock chip back in to see what happens. But beyond that I dont have any idea what could be done if anything. I dont mind burning a little more fuel but maybe a little less than whats being burnt now. But I reckon the manual conversion would balance things out only my diff is 4.27. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 9, 2005 I find the stock chip in mine with the t/b changed is running alot better than before without, definately getting better milage out of the fuel swingometer, better all round Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 9, 2005 That sounds interesting, I dont think the swingometer is as useless as people make it out to be. I will try out the stock chip in the next few days if i can find it. See how it goes. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 9, 2005 That sounds interesting, I dont think the swingometer is as useless as people make it out to be. I will try out the stock chip in the next few days if i can find it. See how it goes. I've found my swingometer to be quite accurate, or at the least, a damn good indication of what you're doing. You really need to ditch the auto box and stick in a low ratio diff if you're concerned about fuel economy. I had a 3.25 ratio diff a while back and that was getting me 44mpg, getting around 36 from the 3.64. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted October 12, 2005 keen as on this upgrade can i please have a list of bits needed and some basic instructions Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 12, 2005 keen as on this upgrade can i please have a list of bits needed and some basic instructions Depends on your engine, with a motronic it's a straight swap (depending on whether you want to upgrade the rubber boot or just make it fit) but with L-Jet there's fiddling to do with the hoses. Just get the bigger t/b first then see if it's going to be a straight swap or if you need to do some fiddling. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted October 13, 2005 its an 87 320i m20 engine, do i need the afm aswell? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 13, 2005 Stop talking bullshit, more power does not always equal less economy no it doesnt however doing it this way does fool Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 25, 2005 Finally swapped the stock chip back in the ecu, So far as I can tell fuel economy has returned to what it was roughly prior to changing the TB. It is pretty close. averaging 10km/1 L Minus the after market chip the car runs much the same only difference I notice is lower idle speed, engine/ exhaust tone sounds deeper, I cant tell if it is any faster or slower, its smoooth. But I think the TB mod is better than the chip alone in my case. not a bad compromise. If I am going to be burning a litre per 7km in a small car I wanna be doing 0-100 in 6.5 seconds or under. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted October 25, 2005 smooth - m20? Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 25, 2005 Smoother than before. but its all pretty subjective I admit. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 25, 2005 smooth - m20? Yip, feels alot smoother, but i'm waiting for a dyno run to see what's really happened Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 26, 2005 I would like to see dyno results too but I cant see myself doing one anytime soon. I am at a bit of a loss with the M20 2l, I am still hesitant to cut the cat out in case I lose any low end torque not that it really has any to beguin with. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 26, 2005 I would like to see dyno results too but I cant see myself doing one anytime soon. I am at a bit of a loss with the M20 2l, I am still hesitant to cut the cat out in case I lose any low end torque not that it really has any to beguin with. Woah, if you've got the stock twin pipe exhasut then cutting the cut out will increase your entire torque range, it made a massive improvement to my car. Quote Share this post Link to post Share on other sites
Coffee&Doughnut 0 Report post Posted October 27, 2005 That sounds reassuring, Would twin 18inch hotdogs keep the noise/ sound within similar range? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 27, 2005 That's what i've done, I stuck a coby resonator on each pipe and the noise is still comfortable, but the car becomes much more rev happy and responsive. Quote Share this post Link to post Share on other sites
