kiwifiat 0 Report post Posted October 20, 2012 Hi Guys, I am after a 5 speed complete with shifter, cross member, slave cylinder and drive shaft to retro fit into a 1968 2000 Tilux. A box of an 4cyl e21 or early e30 fitted with a 4cyl M10 should do the trick. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 21, 2012 Location? I have gbox only from M10 E30 in Helensville. $300. Edit: found what looks to be an almost new clutch plate/pressure plate and a shifter to go with it too. Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted October 21, 2012 (edited) Hi Guys, I am after a 5 speed complete with shifter, cross member, slave cylinder and drive shaft to retro fit into a 1968 2000 Tilux. A box of an 4cyl e21 or early e30 fitted with a 4cyl M10 should do the trick. have a 5spd m10 gearbox, flywheel, linkage and crossmember package available freight shouldn't be a problem let me know if you are interested, bimmersport discount will apply cheers Jon Edited October 21, 2012 by JKSE Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted October 22, 2012 Unless its from an e21 it won't have a speedo drive. There's no way the crossmember will bolt in - the boxes are longer. I modified an e30 one on my 2002tii and it was ok, but would have been better to have fabricated one I think. I used an early e30 shift linkage etc I think - lined up fine with the gear lever hole in the 2002. I think I was able to use an e30 318i driveshaft. I have a spare e30 box, maybe flywheel / clutch / pressure plate but not the rest. Would want $300 for the box, same as westy. Quote Share this post Link to post Share on other sites
kiwifiat 0 Report post Posted October 26, 2012 Unless its from an e21 it won't have a speedo drive. There's no way the crossmember will bolt in - the boxes are longer. I modified an e30 one on my 2002tii and it was ok, but would have been better to have fabricated one I think. I used an early e30 shift linkage etc I think - lined up fine with the gear lever hole in the 2002. I think I was able to use an e30 318i driveshaft. I have a spare e30 box, maybe flywheel / clutch / pressure plate but not the rest. Would want $300 for the box, same as westy. Thanks Cam for the heads up on that speedo issue. It looks like e21 5 speeds are like hens teeth so I will have to come up with a demon scheme to convert the old analog speedo to electronic so I can use a box from an e30. Thanks to those who responded. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted October 28, 2012 Thanks Cam for the heads up on that speedo issue. It looks like e21 5 speeds are like hens teeth so I will have to come up with a demon scheme to convert the old analog speedo to electronic so I can use a box from an e30. Thanks to those who responded. Have a look through rot62's build thread - he fit an E30 one inside the 2002s housing. http://www.bimmersport.co.nz/forums/index....mp;#entry348240 Quote Share this post Link to post Share on other sites
