IIIRII 0 Report post Posted November 2, 2012 Apologies if the answer is already here somewhere obvious and I have missed it. Are E30 / 36 ti axles different lengths between the 4 and six cylinder engines ? As in I think 316 318 have a small case diff and the 320 323 325 has a medium case, therefore the axles should be slightly shorter ??? Is there a shorter axle again ? like from a large case diff , that will fit the e30 e36 ti hub Hopefully that makes sence Thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 2, 2012 (edited) I run a E30 medium case with E30 M325 Axles. You need to modify the Abs speed sensors though and the chassis for the medium case diff to fit. You can give me a call or come and have a look at what I've done with mine. My cars at work Edited November 2, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
IIIRII 0 Report post Posted November 2, 2012 Hi Thanks, I think you have misunderstood the question The car doesnt run a bmw diff. Is there a difference in rear axle length between 4 and 6 cylinder E30's Thanks ' Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 2, 2012 E30 320i's have small case diffs, I have put a medium case diff in my car, and did not change the axles. the M325i ones are slightly thicker, though. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 2, 2012 E30 320i's have small case diffs, I have put a medium case diff in my car, and did not change the axles. the M325i ones are slightly thicker, though. And the CV joints are larger Quote Share this post Link to post Share on other sites
