nzer 0 Report post Posted November 7, 2012 hi, i have bought 51mm strut housings for my e30 bmw and a pair of second hand koni adjustable shocks. My question is when i put the shock into the housing there is sh*t loads of play up and down, when i put it together with a spring and compress it down the shock dosent extend in and out its just the play going up and down. is there suppose to be a rubber spacer at the bottom of the housing to let the shock fit snug? Thanks Quote Share this post Link to post Share on other sites
nzer 0 Report post Posted November 7, 2012 bump Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted November 7, 2012 Have you tightened the top retainer screw that holds the shock int the housing? What sort of adjustable shocks are they? Quote Share this post Link to post Share on other sites
