nipe 1 Report post Posted November 12, 2012 Has anybody done it before? Does anyone want to make one for a price? Thanks Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 12, 2012 i gather your trying to do a tdc sync? you can make a pickup under the rotor inside the disy cap or mount one thru the rocker cover pointing at the cam neither are a five minute job. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 13, 2012 If you're getting rid of the dizzy at the same time, you could make a blanking plate and mount the sensor in that. I think ppf make a blanking plate with a hole in it for sensor Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 13, 2012 If you're getting rid of the dizzy at the same time, you could make a blanking plate and mount the sensor in that. I think ppf make a blanking plate with a hole in it for sensor forgot about that one also alot easier to do Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted November 13, 2012 I just don't want to stuff it up:) And yep, crunchy is onto it, its for tdc sync. necessary stuff to do sequential everything...I've seen a few examples of people's work in states, but not many enough to be sure that the design is working 100%. That's why I wonder if anyone on here done something like that and could help me or do it for some cash. The biggest problem for me is making the bit that attaches onto cam gear instead of the dizzy thingie. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 13, 2012 I just don't want to stuff it up:) And yep, crunchy is onto it, its for tdc sync. necessary stuff to do sequential everything...I've seen a few examples of people's work in states, but not many enough to be sure that the design is working 100%. That's why I wonder if anyone on here done something like that and could help me or do it for some cash. The biggest problem for me is making the bit that attaches onto cam gear instead of the dizzy thingie. ask if anyone on here has a dizzy off a m20 and mod that make things alot easier Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted November 13, 2012 ask if anyone on here has a dizzy off a m20 and mod that make things alot easierI have my old one, how wold i use that, to be honest i have no idea what position or size or etc it has to be.. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 13, 2012 I have my old one, how wold i use that, to be honest i have no idea what position or size or etc it has to be.. what ecu are you using? does it need a analog or digital signal? i make the base plat inside adjustable which makes it easy to put where is needed most ecus only require a signal 60 deg or before TDC thus you don't have to be to accurate to where it sits you can use a pickup from a dizzy like a honda or a ford very small go pick a part costs bugger all Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted November 14, 2012 Awesome will look into that, I'm running megasquirt (haters going to hate) Quote Share this post Link to post Share on other sites
