BlowMyWhistle 0 Report post Posted November 19, 2012 Hi Y'all, My heater controls seem to be stuck in the hot position! I'm not sure when it started doing this, but the top slide for demist, runs hot, regardless of temp settings, cabin floor slide also is hot, same as.. Central slide allows cold air fine! Wtf? I had an e34 a long time ago in a land far far away (NZ) did this to me, blown fuse, heater stayed ON! This is getting to be a pain, can't demist or use aircon without the heater pumping out heat, can someone please give Me a lead in? Is it the solenoids or electrics?? 5 years this week I've had this car, not looking forward to another aussie summer with the heater going... Cheers Y'all. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted November 19, 2012 heater soliniods valves get stuck . pull them apart and clean and check them or replace them. make sure you have 12volts going to them when set at cold with engine on first. Quote Share this post Link to post Share on other sites
BlowMyWhistle 0 Report post Posted November 19, 2012 heater soliniods valves get stuck . pull them apart and clean and check them or replace them. make sure you have 12volts going to them when set at cold with engine on first. Take it to the shop! Looked up the heater diagrams, could be temp sensors, cables etc...Let somebody else do it, not as huge a job as I had envisioned perhaps? Cheers Quote Share this post Link to post Share on other sites
