Docile
Oil in Radiator
Ok so cousin's 318i e46 has a lot of oil in the radiator. car has been at the mechanics and said there is no water in the engine oil so probably its from the transmission.
transmission specialist just called and said there is no water in the transmission to suggest a leak.
anyone got an idea to what the problem might be?
If it's an N42 motor it may be the engine oil cooler. What motors in the car ?
not sure. its a 2001 318i e46 touring. dont have the vin on hand as car is still at the transmission specialist having a trans service.
I have a dye here that could solve the mystery....give me a call
Edited by *Glenn*
