d.p.n.s 15 Report post Posted December 3, 2012 hi all just wondering if all e30 half shafts are the same i.e could i use a 316i half shaft in a 320i? cheers Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted December 3, 2012 hi all just wondering if all e30 half shafts are the same i.e could i use a 316i half shaft in a 320i? cheers need to check if its disc brake rear end or drum brakes . also wether from a small case diff or medium case diff most 320i use small case like a 316i etc but check if it had drum or disc brakes so there are 4 options to choose from Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted December 3, 2012 thanks you very much for that mate Quote Share this post Link to post Share on other sites
