RhoanW
HVAC problems
I found this when searching...
For those of you who's with the E36ers and would like to know the what the HVAC codes are, check this out:
HVAC Hidden Test Functions (Climate Control) - E36
The HVAC (Heating, Ventilation, Air Conditioning System) of the 1996 E36 has
a feature allowing different sensor values to be displayed on the control panel.
To Access the Display Function:
Press the "AUTO" and "REAR DEFROST" buttons simultaneously.
12 displays are available.
Toggle through them by pressing the fan rocker (+ or -) switch.
Number
Test Function
1 Interior Temp Sensor
2 Exterior Temp Sensor
3 Left Heater Core Sensor
4 Right Heater Core Sensor
5 Evaporator Temp Sensor
6 Engine Speed Input
7 Road Speed Input
8 "Y" Factor Value
9 Fresh Air Flap Position (%)
10 AUC Sensor Voltage
11 Battery Voltage
12 Software Version
To Exit the Display Function:
Press the "RECIRC" and "AUTO" buttons simultaneously, or
Turn off the Ignition.
Note:
1. Decimal Points are not shown, Hence 75.5% is displayed as 755.
2. All Temperature displays are in ?C (Centigrade).
3. Negative values are indicated with minus sign
Does this apply to the E39's as well? I am having problems with my HVAC. I don't get cold air, warm air or hot air. It was raining lastnight and I couldn't get windscreen de-misted. Any help will be GREATLY appreciated.
