antil33t
HubCentric Rings O.D. 74.10mm I.D. 72.56mm
Need a set, Have absolutely no luck at all locally.
Was even told a by a wheel shop here that they use insulation tape. - Probably need more tape LOL
Seems that they are only common overseas......
Contact Harvey - Harvgray on here
Tape sounds a bit hori!
I bought mine off ebay for like $10 or so, good quality plastic ones.
Might have, no idea on sizes but were for a set of RS-GTs to go on my E30 back in the day
E30's use a 57mm C.B I think.
Tape IS hory. and you need 6laps of it to make the wheels not shimmy hahah.
Will contact that fella shortly, probably not interested in doing work at this time of the year!
Easy to get from the Bridgestone in Parnell. Have bought two sets in the last few month. About $40 IIRC.
Just noticed your in Dunners. Still Bridgestone Direct is a chain, so I'm guessing the nearest one can get some in.
if your still looking after christmas i can machine some up for you,
flick us a pm if your interested
