risenfan 0 Report post Posted January 2, 2013 i got an BMW 318I E46. it's got some oil leaking and i suspect its the gasket. yesterday the engine overheated and i pulled of straight away once i noticed it. ive since put some more water in there so i can drive it home. there's no water in the radiator but i see no obvious water leakage. any idea what's the problem and how much will it be to get it fixed? many thanks guys!!! Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted January 2, 2013 i think you will need to get it into a garage to properly check it out and see where the problem is could have allsorts of issues , needs to be checked . can be failed watewr pump , leaky radiator, broken thermostat , leaking hoses , split plastic coolant pipes etc etc blown head gasket , what location are you in??? Quote Share this post Link to post Share on other sites
risenfan 0 Report post Posted January 2, 2013 i think you will need to get it into a garage to properly check it out and see where the problem is could have allsorts of issues , needs to be checked . can be failed watewr pump , leaky radiator, broken thermostat , leaking hoses , split plastic coolant pipes etc etc blown head gasket , what location are you in??? thank you for the quick reply mate i think its a good idea to go to a workshop too. im in Hamilton mate. Quote Share this post Link to post Share on other sites
