Shady
Radiator Flush M20 E30
Am thinking of giving the E30 a radiator flush soon and refill with some fresh coolant & water.
Does anybody known how many litres to completely full it back up, for an M40 motor? Coolant vs Water (how many Ls of each) is recommended? Coolant will be the normal anti-boil/anti-freeze stuff.
http://hellafunctional.com/?p=629
Here in New Zealand it's not REALLY that cold... it's unlikely to freeze if you just use tap water... but then you'll end up with something worse than a frozen radiator.
I use 30% myself...
If you're concerned about boiling points of water... an M20 E30 pressure cap is 1.3bar a later BMW has a 2.0bar cap.
Edited by antil33t
yea a 2.5L bottle of nulon long life green concentrate would be ideal. about $30 i believe.
pour the whole bottle in then fill the rest of the way with water
Shot. Cheers guys. Next weekends mission. Much appreciated.
