Drea//Mer 30 Report post Posted January 18, 2013 Does the e36 318i run a different fuel pump to the e36 325i? Im getting very close to firing up the m50tub25 that i just swapped into my 318i, I've just reconditioned my injectors with new o-rings and microfilters and pintle caps but before i fire the engine up i want to make sure im not going to starve it of fuel. Also what kind of manifold sealant should i use between the plastic intake and the engine? Thanks -Kieran Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 18, 2013 They both run 3 bar without vacuum & 2.5 bar with vacuum. No sealant required on the gasket... just new gaskets and a little rubber grease. Quote Share this post Link to post Share on other sites
Drea//Mer 30 Report post Posted January 18, 2013 They both run 3 bar without vacuum & 2.5 bar with vacuum. No sealant required on the gasket... just new gaskets and a little rubber grease. oh great so they 318 fuel pump will work just fine? time to go buy new gaskets =) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 18, 2013 I'm running the M44 fuel pump with the M52B28 in my 318ti with no problems Quote Share this post Link to post Share on other sites
Drea//Mer 30 Report post Posted January 18, 2013 update: intake gaskets are $65 at bnt, my poor bleeding pockets! Quote Share this post Link to post Share on other sites
