Drea//Mer 30 Report post Posted January 22, 2013 Hey guys, turned the key for the first time on my engine swapped 318i today, got dash lights but when i went to start the car the starter went click and i lost power to everything! The engine swap is an OBD1 1993 m50tub25 into a 1995/6 OBD2 318i e36, to i need to cut any wires to bypass the immobilizer? Also im not sure if these relays are oriented correctly... anyone got a working 325i for an example? After messing around with the battery and interior lights i got dash lights back but im too scared to turn the key any further!! Thanks -Kieran Quote Share this post Link to post Share on other sites
Drea//Mer 30 Report post Posted January 22, 2013 update: im half blind!, not really but my face is burning. The relays seem to be correctly oriented, starter motor is turning over... i wasnt sure if it was getting fuel so i undid a fuel line which had a lot of back pressure and spewed petrol all over my face =(. I reversed the fuel lines to the fuel rail in case i had them backwards. Does it matter which way the fuel goes into the fuel rail? Still hasnt started yet but its cranking which is progress. Im thinking theres a wire i need to snip for it to start (i've seen info on this before when others did OBD1 engine ->OBD2 chassis conversions) Quote Share this post Link to post Share on other sites
Drea//Mer 30 Report post Posted January 24, 2013 another update, just in case anyone else has trouble with this sort of swap. Got the engine running by cutting green wire #7 in the front 25pin engine harness plug, after some research i found this is the signal wire for the ews system to tell the dme not to fire spark / inject fuel. sorry for all the dumb questions! this is my 2nd engine swap and i have no mechanical training so im learning a lot as i go.. Very pleased with my success today, the 325 motor roars with no exhaust! -Kieran Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 24, 2013 At least there was no more face burning! Well done! My secong engine swap was a 1.8 auto Impreza to 2.0 manual - had to split and merge the two car looms... my wife was PISSED when she saw what I'd done It went back together OK though. Quote Share this post Link to post Share on other sites
