rxsumo 33 Report post Posted January 30, 2013 Hi I''m reassembling my 3.0Si, and I'm trying to track down a couple of parts. A centre console for a '73 or later E3..prefer 3.0S or Si, and prefer a manual one. The specific bits I'm after is the woodgrain filler panel that forms the console floor, and the chipboard "rear wall" for the console and the support wires for this rear wall. The E3 was fitted with aftermarket air con, which meant that the original console had been cut down, and the floor filler was missing as a radio panel had been made to fill the space between the gearlever and the vents. A FI fuel pump for a E3 or E12, I dont actually need the pump itself, I'm after the fuel swirl pot that sits below the pump (the swirl pot also has the bracket for mounting the pump) Looks like an axle had come adrift at some stage and smashed both the swirl pot, and the brake bias control valve. For either parts happy to buy complete assemblies to get the parts I need. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted January 30, 2013 i have a 525 carb model 1977 4spd manual parts car , if there are any parts you need off that?? Quote Share this post Link to post Share on other sites
Deano 1 Report post Posted January 30, 2013 I have a medium case sideloader LSD 3.45:1 Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 30, 2013 I'm after the fuel swirl pot that sits below the pump (the swirl pot also has the bracket for mounting the pump) Pretty sure this will be the same as on a 2002tii (I checked the online catalogue - same part number by the looks). Theoretically I have it. Somewhere. I'll look, but don't hold your breath (sorry!). Quote Share this post Link to post Share on other sites
