Wom
E36 Left Brake Light Issue
Hi
Car = 1996 E36 323i Coupe, Jap import
The left brake light stopped working, so I pulled the bulb and it was rather brown. I replaced it with a new one ... but still not going. My first thought was the contacts on the little plastic unit you put the bulb into, gave them a going over with a wire brush, put the bulb back in, still not going. I then switched over the plastic unit with the working right hand side, and it goes on the right but not the left.
So it's not the bulb, and it's not the contacts on the little platsic bulb holder .... I looked into the plastic housing where the bulb unit goes in, gave the contact in there a scrubbing with the wire brush ... still not going.
All the other lights are fine, so I don't think it's a fuse ... what else should I look for?
Cheers
the metal plates that the bulb holder twists into get burnt out etc
replace the tail light unit with another
  Wom said:
sweet, will do
cheers
have new and used ones
clear and amber corner types
  Wom said:
sweet, will do
cheers
Hi Chris
pop in and see me , when you get a chance
cheers
Jon
