Flow 1 Report post Posted February 18, 2013 (edited) Hi guys. I have just fitted Bilsteins to my NZ new E39 540i M-Sport which some of you will know is in rather ridiculously good condition especially as I keep on replacing things that were perfectly OK :/ These are her shocks that have only done 78,000 ks I'm sure they will improve someone's ride. They are the M-Sport II versions that used mostly M5 parts. I am throwing in the front strut top mounts with bearings as I may also have fitted some beautiful Ground Control camber plates so that I can get the front alignment bang on. You may need to get new rear bottom spring pads if you are retrofitting but I doubt it. All bump stops and boots included. $100 first in first served Edited February 18, 2013 by Flow Quote Share this post Link to post Share on other sites
Smac01 12 Report post Posted February 18, 2013 Would these fit the front of my E39 530i touring? Keen to lower it slightly but figure lowering springs with msports shocks would be better than OEM shocks. (That's if they even fit?) Cheers Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted February 18, 2013 afaik e39 v8 front struts won't fit e39 6 cylinder models. Quote Share this post Link to post Share on other sites
Flow 1 Report post Posted February 21, 2013 Winckel said: I'll take them!!!! 0900 40 40 40 SOLD! Thanks Sam. Quote Share this post Link to post Share on other sites
