albert72 0 Report post Posted March 23, 2013 (edited) Not having a good week. Was about to leave this morning, turned on the ignition and EML and ASC lights up, car won't start. Use a scan tool and P0120 and P0220 errors comes up. Tried erasing the fault but no luck. Any ideas??? Edited March 23, 2013 by Tom325 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 23, 2013 (edited) They are both throttle potentiometer fault codes A & B circuits. Throttle pedal & Throttle body Try turning ignition on...slowly move the throttle pedal up and down from O to full throttle half a dozen times. Turn ignition off , then on, and try starting again Edited March 23, 2013 by *Glenn* Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 23, 2013 (edited) They are both throttle potentiometer fault codes A & B circuits. Throttle pedal & Throttle body Try turning ignition on...slowly move the throttle pedal up and down from O to full throttle half a dozen times. Turn ignition off , then on, and try starting again Tried that one but still no joy. I've also tried resetting the fault before and after the doing the up and down with the pedals Edited March 23, 2013 by Tom325 Quote Share this post Link to post Share on other sites
albert72 0 Report post Posted March 24, 2013 bump Quote Share this post Link to post Share on other sites
