Freddie 0 Report post Posted April 10, 2013 Hi there I'm new here but I have a question. I just installed a set of LED H11 light bulbs with canbus. When car starts up the fog lights will flicker a few times (but they still work fine) is it normal???? please help Quote Share this post Link to post Share on other sites
Escay 0 Report post Posted April 10, 2013 Yes, it's normal, when the car starts up it runs an electrical signal to all lights. Its called bulb check, this affects LEDs they tend to flicker. The only way to remove the flicker is to code out the bulb check. Quote Share this post Link to post Share on other sites
Freddie 0 Report post Posted April 10, 2013 Yes, it's normal, when the car starts up it runs an electrical signal to all lights. Its called bulb check, this affects LEDs they tend to flicker. The only way to remove the flicker is to code out the bulb check. thanks for your reply mate. as long as its safe than it's all goods. cheers Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted April 24, 2013 thanks for your reply mate. as long as its safe than it's all goods. But likely not compliant with the road code.... Quote Share this post Link to post Share on other sites
