Mr2low 57 Report post Posted May 15, 2013 cracked and flaking worth DIYing or just get a pro to do it, top is pretty much all gone, passengers side is getting there still water tight though Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 15, 2013 Just get a replacement fitted. It is only a trim - the screen is glued in. Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted May 15, 2013 (edited) Hi mate I bought the part from Team McMillan and fitted it myself quite easily. I can't remember who I asked but they said that I needed to have the windscreen taken out (and associated higher cost) but I'd read on the M5Board(?) that it could be done without removing. IIRC part was about $130. Have a Google, there's a guide around somewhere. Edit: Here you go http://forums.bimmerforums.com/forum/showt...rim-replacement Edited May 15, 2013 by Tristan Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted May 15, 2013 Yep, it's easy. I did front and back on mine. Buy online or from one of forum sponsors that stocks new parts (I know that Gavin @ Euroitalia or Brent @ BMWorld do) as it will be way cheaper. Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted May 16, 2013 yeah found the m5 board post after i posted lol coz a few of the things i saw said it was pull out windscreen job. Will add it to a very small list of to do's Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 16, 2013 Cant see how you need to remove the screen to fit the trim. The screen is eurothaned in, how the hell can you fit the screen in the first place with the trim already fitted? Quote Share this post Link to post Share on other sites
RustyItalian 11 Report post Posted May 16, 2013 Be a bugger if your windscreen cracked and you had to get a brand new BMW one fitted with a brand new BMW seal... ;-) Quote Share this post Link to post Share on other sites
