Wom
handbrake install help
Hi
I got the old handbrake shoes off ok, but I can't get the new shoes on
In particular I'm having real difficulty with the springs
Any hints and tips to getting the buggers on?
I was using their book to guide me through it, but didn't think of checking their website
"the long springs are easy with a zip tie around one end...just pull apart with one hand and use a plier to remove or replace the tip you just pulled free"
genius, I'm going to try that
no matter how hard I tried, I just couldn't get the spring down far enough to get back into the hole in the bottom shoe
finally sorted
was a lot easier with daylight, and a helper to hold the shoes in place
left side was a lot easier and quicker
really the only trick is to have both hands on the pliers and use a lot of muscle
