BreakMyWindow 1999 Report post Posted May 30, 2013 It appears I have a rather odd system in the M5. Has the Mk2 4:3 onboard monitor, but no dsp, and no hifi - just 6 speakers - I couldnt see an amp in the boot with the 9pin and 26pin connector for the 10 speaker arrangement. There is also a seperate MID in the rear centre console, that has the ability to change stations, switch between radio, tape and cd. The OBC functions can also be displayed. Thinking that I did have the amp, I was just going to install a small old-school Alpine 2 channel amp to power a sub to fill in the low end. I have done this on my previous 540i that had the 10 speaker hifi system, and was happy with it, as im not cranking it up passed 11 like i used to when i was younger. So with the stereo I have in the M5, i'm wondering how many watts continuous is being powered to the 6 speakers? Im thinking about just replacing the front 5.25 woofers and tweeters with some mid-range Alpine component units. I'm not going to bother though if the output is something really measly like <5 watts rms per channel. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 2, 2013 It appears I have a rather odd system in the M5. Has the Mk2 4:3 onboard monitor, but no dsp, and no hifi - just 6 speakers - I couldnt see an amp in the boot with the 9pin and 26pin connector for the 10 speaker arrangement. There is also a seperate MID in the rear centre console, that has the ability to change stations, switch between radio, tape and cd. The OBC functions can also be displayed. Thinking that I did have the amp, I was just going to install a small old-school Alpine 2 channel amp to power a sub to fill in the low end. I have done this on my previous 540i that had the 10 speaker hifi system, and was happy with it, as im not cranking it up passed 11 like i used to when i was younger. So with the stereo I have in the M5, i'm wondering how many watts continuous is being powered to the 6 speakers? Im thinking about just replacing the front 5.25 woofers and tweeters with some mid-range Alpine component units. I'm not going to bother though if the output is something really measly like <5 watts rms per channel. Depending on what radio module is fitted, it'll be either: BTL, delivering "high power", around 25W RMS per channel (4 channels) non-BTL, delivering "low power" around 6W RMS per channel (4 channels) So tell us what radio module is fitted (read the label on the module, or query it using NavCoder) Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted June 6, 2013 Thanks Jochen, will do. Quote Share this post Link to post Share on other sites
tangalife 1 Report post Posted June 6, 2013 On this, how much watts is being powered to the speakers on a system with the amp in the boot? I have the 4:3 monitor, 1997 540i Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 14, 2013 On this, how much watts is being powered to the speakers on a system with the amp in the boot? I have the 4:3 monitor, 1997 540i With or without DSP? With or without subwoofer? Standard amp: DSP Amp: 10 Channels x 25W per channel = 250W (Front = 6 channels, rear = 4 channels) Standard Amp: 25W per bass channel = 4x25 = 100W 15W per mid and per high range channel = 6x15 = 60W Total = 160W Add subwoofer at about another 30W per channel, 2 channel, = another 60W or so. Quote Share this post Link to post Share on other sites
