kiwi6539 3 Report post Posted May 31, 2013 Hi. Need to get bushes tomorrow as car in workshop. Anyone have any idea of anywhere in wellington region that may have and open Saturday? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted May 31, 2013 Hi. Need to get bushes tomorrow as car in workshop. Anyone have any idea of anywhere in wellington region that may have and open Saturday? Page European may have something in stock more likely to be oem type,they arent always open on a saturday am Quote Share this post Link to post Share on other sites
kiwi6539 3 Report post Posted June 4, 2013 Hello. Can anyone advise me on brands or what company make polyurethane bushes for the E34. The nolathane brand don't fit have a flat edge and original bushes are almost a full round bush. And wouldn't fit. Do you have to adapt any aftermarket bushes to fit the anti roll bar sway bar. Front bar. 23mm Rear bar. 15mm And want to replace rear drop links too. With polyurethane or urethane bushes if can get them. Any advice would be great thank you Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted June 4, 2013 I used Nolathane brand bushes before and i ended up machining the original sway bar brackets down to fit them in. Ive only ever had to do with them out of the many brands ive used. Usually gone with Powerflex myself from ebay or NZAD Poly sway bar links usually only come with swaybar kits as they normally attached differently compared to std bmw bars. Adjustable links would a better option as they should be stronger and you can adjust preload but overkill imo for a std street car. Quote Share this post Link to post Share on other sites
