M3_Power 636 Report post Posted June 7, 2013 (edited) One of only 2 made here in NZ - the other one is on ex-Mike Eady's E92 M3 race car. This is the second one that was in the process of being made for my car before I ended up selling the car. It is half complete but can be finished in 2 weeks time once a deposit is received. Dimensionally correct to the real thing - the main plane of the wing is taken directly from the WTCC rear wing which is what the M3 GTS wing is based from - the uprights are moved outward - the actual positioning distance was measured off a real GTS wing (from a friend in Germany) - the uprights are also done on the correct GTS template. The end plates are not 100% accurate, but very close. This will be the last one made and that's it. Aluminium construction with structural foam like the WTCC wing - almost identical in weight also to the real thing. Please note the wing is primered not painted. 53kg rear downforce $800 Edited June 7, 2013 by M3_Power Quote Share this post Link to post Share on other sites
Driftit 2219 Report post Posted June 7, 2013 Hmmm I am looking for a wing. But I am not sure this will look right on the big E34. Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted June 10, 2013 Hmmm I am looking for a wing. But I am not sure this will look right on the big E34. Might be a bit narrow I think .... hmmmmm Quote Share this post Link to post Share on other sites
