Etwenty1 45 Report post Posted June 11, 2013 Warning: date_default_timezone_get(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Pacific/Auckland' for 'NZST/12.0/no DST' instead in /srv/bimmersport.co.nz/bimmersport.co.nz/www/htdocs/forums/init.php on line 269 Quote Share this post Link to post Share on other sites
HappyH00ker 30 Report post Posted June 11, 2013 Warning: date_default_timezone_get(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Pacific/Auckland' for 'NZST/12.0/no DST' instead in /srv/bimmersport.co.nz/bimmersport.co.nz/www/htdocs/forums/init.php on line 269+1 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 11, 2013 +1 +2 Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted June 11, 2013 +1 +2 =3 Shows up in the 'Attachments' Down here VVVVV And all the text is blind man spec, I'm not that old.... Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted June 11, 2013 http://www.bimmersport.co.nz/forums/index....c=44885&hl= Quote Share this post Link to post Share on other sites
