E30320i 1 Report post Posted June 13, 2013 These wheel nuts cam with a set of Wheels i purchased a while ago and i have been planning on doing a stud conversion for the ease of changing wheels, and the fact i can use the wheel nuts i was giving http://rayswheels.co.nz/html/rays_gear.html I realise they are 50mm long, and the range is 35mm of thread i believe I have done some research and thought these studs would be the best, http://www.vorshlag.com/product_info.php?c...products_id=389 but im not sold as i dont want to buy them as they might not work with the wheel nuts, Any advice? or solutions? Cheers Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted June 13, 2013 Seems like you've done all the right research, doesn't matter if the nuts are longer then the studs if that's what you mean? Quote Share this post Link to post Share on other sites
bennjazz 0 Report post Posted December 3, 2013 Soooo are you thinking of selling your wheels in future? Quote Share this post Link to post Share on other sites
E30320i 1 Report post Posted January 26, 2014 Seems like you've done all the right research, doesn't matter if the nuts are longer then the studs if that's what you mean I guess ill have to measure the distance between the two, so the stud doesnt hit the end of the Nut before the nut is fully screwed in to the wheel If that makes sense haha Quote Share this post Link to post Share on other sites
E30320i 1 Report post Posted January 26, 2014 Soooo are you thinking of selling your wheels in future? Ahh Not anytime soon haha, Just looking for some coilovers atm Quote Share this post Link to post Share on other sites
