dr_kahu 8 Report post Posted June 19, 2013 Hey, My missus brought a car and it already had an aftermarket PDC applied for the rear only (the type which just beeps, no screen/display). It appears that all but one is non-functional (did the 'click' test). Rather than plug the holes, I thought I'd try and at least fix it. My question is (not knowing the brand) are all aftermarket sensors interchangable? I do realise they can 'look' different, but is there like an 'ISO' for the plug-end on the PDC?/are they universal? I haven't taken the bumper off for a proper look yet. cheers Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3013 Report post Posted June 19, 2013 From the PDCs I have worked with there is no standard for the actual sensors nor the connectors on the back are made to a standard to allow inter-changing. That said, the sensors are made by only a handful of suppliers rather than the car companies, Bosch, Siemens, etc and there are not a huge number of different types. If you can get the non-functioning ones out they may well have the makers name and part number on them, so you can source replacements, worst case you might need to Google it. Quote Share this post Link to post Share on other sites
dr_kahu 8 Report post Posted June 20, 2013 Thanks mate. Quote Share this post Link to post Share on other sites
dr_kahu 8 Report post Posted June 21, 2013 I had a crack at it last night. It appeared to be installed by some outfit in Auckland called "ThirdEye". Unfortunately it appears that 3 of the 4 sensors are not working, so might just disconnect the audible error sound and then look into it later on. Quote Share this post Link to post Share on other sites
