nickbawt 0 Report post Posted June 26, 2013 Hi Team, Currently overseas and am planning my budget for the E39 on my return. Its due for its inspection II but unsure how much I need to budget off for it. Can anyone give me a rough idea on cost assuming little needs to be done? $1500? $2000? I would ring around but am overseas so it could get expensive. Cheers for any feedback. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted June 26, 2013 woooah. I've never done a full inspection 2 as I choose to do alot of the work myself to ensure I get the best parts but i'd say more $1000 than $2k. inspection 1 cost me $400 last time if I remember. Anyone done one recently that can confirm? Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted June 27, 2013 If its more than 800-900 youre getting ripped Quote Share this post Link to post Share on other sites
allan 295 Report post Posted June 27, 2013 No idea of the possible cost but this is what I found on a forum BMW Inspection 2 Service - Here's what it involves! BMW MAINTANENCE: INSPECTION II Date: Mileage: Inspection I 1. Undercarriage ï± Change oil and oil filter ï± Check transmission for leaks ï± Check rear axle for leaks ï± Visually check fuel tank, lines and connections for leaks ï± Check condition, position, and mounting of exhaust system. Exam for leaks. ï± Check power steering for leaks. Check fluid level, add if necessary. ï± Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc. ï± Check overall thickness of front and rear disc brake pads using special tool. If replacement is necessary: Examine brake disk surfaces. Clean brake pad contact points in calipers. Grease wheel-centering hubs. Check thickness of parking brake linings only when replacing rear brake pads. ï± Check brake system connections and lines for leaks, damage and incorrect positioning. ï± Check for free movement of the parking brake cables. Adjust if necessary. ï± Check all tire pressures (include spare). Correct if necessary. Check condition of tires (outer surface (left/right)), tread wear and pattern; in case of uneven tread wear, readjust wheel alignment if requested. 2. Engine Compartment ï± Read out diagnostic system. ï± Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level. Add coolant if required. ï± Check level of brake/clutch fluid in reservoir. Add fluid if required. ï± Check windshield washer fluid level and antifreeze protections. Fill up and/or correct if required. ï± Check air conditioner for operation. ï± Reset service indicator. 3. Body/Electrical ï± Check battery electrolyte level and add distilled water if required. ï± Perform battery load test. ï± Check lighting system, i.e.: headlights, foglights, parking, back-up, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment/area lights. ï± Check instrument panel and dashboard illumination. ï± Check all warning/indicator lights, check control. ï± Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer and flasher switch. ï± Check wipers and washer system(s); wiper blades, washer jet positions. ï± Check condition and function of safety belts. ï± Visually examine the SRS airbag units (Driver and front p***enger) for torn cover, obvious damage or attachment of decals, decorations or accessories. ï± Check central locking/double lock. ï± Replace batteries for alarm remote controls in all master keys. ï± Oil hood, trunk and door hinges. Grease hood, trunk/tailgate and door latches. Check operation of all latches. ï± Replace microfilter. (Note: Reduce replacement interval in dusty operating conditions). ï± Check heater/air conditioner blower, rear window defogger. ï± Check rear view mirrors. 4. Final Inspection ï± Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission. Inspection II 1. Undercarriage ï± Half-shafts: Check for leaks at flexible boots. ï± Inspect entire body according to terms of rust perforation limited warranty. (Must be performed at least every two years). 2. Engine Compartment ï± Replace spark plugs. ï± Replace air cleaner element. (Note: reduce replacement interval in dusty operating conditions). 3. At Every Second Inspection II ï± Change oil in manual transmission while at normal operating temperature. ï± Change oil in rear axle while at normal operating temperature. ï± Check clutch disc for wear. 4. Brake Fluid Service (Replace brake fluid every 2 years (time interval begins from the vehicles production date) 5. Cooling System Service (Replace coolant every 3 years (time interval begins from the vehicles production date) 6. Oxygen Sensor Service (Replace Oxygen Sensor every 100,000 miles) Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 27, 2013 (edited) indy or dealer? my guess is 500 to 1000 Edited June 27, 2013 by kiwi535 Quote Share this post Link to post Share on other sites
nickbawt 0 Report post Posted June 27, 2013 It'll be going to an indy, thanks for your feedback guys. Ill put away a grand for it to cover any surprises. Its strange I seem to remember someone telling me the inspection II was expensive, 2k+. Thanks again Quote Share this post Link to post Share on other sites
mrphil 1 Report post Posted June 28, 2013 You can ring up a dealer and get a ballpark figure, they should know a rough price but all depends on how maintained the car has been Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted June 28, 2013 numbers I gave were for a dealer (JC BMW) , feel free to pay more and get less from a non BMW repairer, This comment does Not apply to the likes of BM Workshop who are excellent and currently do both of my cars. Last inspection 2 on the X5 was $450.00 450 would barely cover all the fluids! Quote Share this post Link to post Share on other sites
