JJohnsen88 9 Report post Posted June 30, 2013 I'm thinking of changing my thermostat as the car runs cold 90% of the time only in slow traffic does it normalize so from experience these symptoms tell me this needs to be done, however, I'm wanting to know 1) Where do I find a good quality thermostat in Dunedin without going to Cooke Howlison BMW and paying an arm and a leg and how much? 2) If replacing thermostat doesn't solve the problem what would the next most logical option be? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted June 30, 2013 Try Paul at miland, he sells plenty of oem quality parts on trademe and is local. But if your doing the thermostat you should probably look at doing the water pump aswell as they can fail if it's old -only about 100buks. Also good time to check over the hoses etc to sell if they need replacing. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 30, 2013 (edited) Definitely Paul.. Genuine from Cookies probably isn't that much more though. +1 for waterpump For running cold, probably is the thermostat. my E34 (same engine) was exactly like this when I got it, someone had pried the thermostat open like a typical ignorant kiwi. Being a 1992 I assume it has a metal thermostat housing too anyway, so no need to get the "better" metal one. Edited June 30, 2013 by antil33t Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 1, 2013 Oyea, if it is the plastic housing for the love of god!!!! Replace it with the alloy one. If you dont, I (and many others) will garentee youl crack it replacing the t.stat. I know I did! Quote Share this post Link to post Share on other sites
BMRBOI 8 Report post Posted July 1, 2013 Yep what he said. It's not fun parking up at the petrol station with a whole lot of fresh coolant over the floor court. Oyea, if it is the plastic housing for the love of god!!!! Replace it with the alloy one. If you dont, I (and many others) will garentee youl crack it replacing the t.stat. I know I did! Quote Share this post Link to post Share on other sites
