nz318i
E30 suspension
Hey everyone im new and ive got a 318 and iam wanting to put adjustable coil overs in. so i can have to really low and handle mint. What u rekon?? any other sugestions would b gud
Are you sure that a 318 is a candidate for a true coilover suspension? Judging by the spelling, it might be a tad much to sink into your car...?
Really low and handling mint doesn't necessary corellate.
Be prepared to fork out for new tyres every 6 months as I've found with the 325i on superlows - thank god I have an abundance of wheels.
That or modify the suspension as mentioned on here before which I'm planning on getting around to!
i "rekon" its a contradiction in terms.
if you want a sill scraper it wont handle.
maybe you could have the first air bag set up here
gangsta stylez yo
Edited by 325GRANT
Guest Spargo
Ground Control Coilovers with adj spring perches, or KW Variant 2's. Both will go low and handle bloody well.
You'll also need to notch your subframe for adjustable camber, and be prepared to spend around 5k, to have what you want, ie: the best of both worlds: low and nimble, usually without tonnes of cash, these two are mutually exclusive.
