shane525i 0 Report post Posted July 12, 2013 hi there, I need to change the drive belt on my 2002 525i is it something I could do at home ,or is there some bmw tools I would need . radiator out ? Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted July 13, 2013 radiator out would probably be much easier. I havent done one on a 6cyl but being they have issues i would be looking at its history and considering doing the waterpump, thermostat, hoses and radiator while its out. also viscous coupling. worth inspecting anyway. And doing a coolant change if the rad is coming out anyway Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 13, 2013 radiator out would probably be much easier. I havent done one on a 6cyl but being they have issues i would be looking at its history and considering doing the waterpump, thermostat, hoses and radiator while its out. also viscous coupling. worth inspecting anyway. And doing a coolant change if the rad is coming out anyway Rubbish... you don't need to remove the radiator and do all that to change a drive belt. Remove viscous coupling, raise the shroud to remove it and change the belt Quote Share this post Link to post Share on other sites
shane525i 0 Report post Posted July 13, 2013 Rubbish... you don't need to remove the radiator and do all that to change a drive belt. Remove viscous coupling, raise the shroud to remove it and change the beltyep this e39 is like new under the bonnet,however the drive belt is behind the aircon belt so I"d do both belts at the same time.does the top of the shroud separate ,by undoing those plastic clips ? would be nice to have a workshop manual anyone know where I could get one? thanks shane. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 13, 2013 yep this e39 is like new under the bonnet,however the drive belt is behind the aircon belt so I"d do both belts at the same time.does the top of the shroud separate ,by undoing those plastic clips ? would be nice to have a workshop manual anyone know where I could get one? thanks shane. The AC belt comes off by releasing the tensioner from underneath the car. You remove the two retainer clips on the shroud, undo the viscous coupling, lift the shroud and remove the fan & coupling. You can then change the alternator belt. If this is out of your range of abilities... get a professional to do do it for you Quote Share this post Link to post Share on other sites
shane525i 0 Report post Posted July 13, 2013 The AC belt comes off by releasing the tensioner from underneath the car. You remove the two retainer clips on the shroud, undo the viscous coupling, lift the shroud and remove the fan & coupling. You can then change the alternator belt. If this is out of your range of abilities... get a professional to do do it for youcool thanks for the help ,sort of what I thought . be a lot easer to do it up in the air so I think ill get the workshop to do it. many thanks. Quote Share this post Link to post Share on other sites
