MilesP
E36 GM Transmission
Have a 93 E36 318i with the GM automatic.
98000kms on the car and no error codes etc.
The car shifts just fine and smooth. When I got the car the thermostat was not right and so temp was everywhere. I replaced it and now the car doesn't like changing into last gear when its cold.
Occasionally it will change if I just drop all power and return it. Almost as if it would hold gear if I was going up a hill.
When the car warms up though absolutely no problems.
Could it just be a case of changing gearbox oil? Or is this commonly caused by some thing else?
