sascha
E46 318i Battery Replacement
I'm just about to head off to supercheap to buy a new battery for my old man's e46 318i touring, and I thought I'd quickly check if anyone had any particular recommendations for ideal replacements?
The current battery is original BMW, part number 90 60 0 305 136 and is rated at 55ah and 480CCA.
Am I right to think that as long as I get a battery with at least the same amp hours and cold cranking amps ratings, it'll be fine (and similar dimensions, terminals on the same side, etc)?
Also check to see if it has a hole for the battery to vent to the outside atmosphere via plastic tube.
Thanks, already bought one (with the vent!).
