e30ftw 433 Report post Posted August 7, 2013 (edited) Anyone got a FL type towbar that bolts onto rear bumper? Want one that can be fitted easily without having to drill millions of holes as a temporary bolt on / off when needed. (Wellington preferred) Edited August 7, 2013 by e30ftw Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted August 7, 2013 Anyone got a FL type towbar that bolts onto rear bumper? Want one that can be fitted easily without having to drill millions of holes as a temporary bolt on / off when needed. (Wellington preferred) have fl towbars , but they do not bolt to the bumper, your bumper is plastic Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted August 7, 2013 (edited) have fl towbars , but they do not bolt to the bumper, your bumper is plastic How do the ones you have fit? I would remove bumper to install, Just temporary. Wouldn't want to chop the tech2 rear just for a tow bar. I worded it wrong I believe, I mean I want one that fits into the bumper mounts, then normally standard bumper bolts ontop. I want one I can easily bolt on by taking my rear apron off and bolting on easily. Already have wiring plug hiding behind the bumper just want a bar. Edited August 7, 2013 by e30ftw Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted August 7, 2013 How do the ones you have fit? I would remove bumper to install, Just temporary. Wouldn't want to chop the tech2 rear just for a tow bar. I worded it wrong I believe, I mean I want one that fits into the bumper mounts, then normally standard bumper bolts ontop. I want one I can easily bolt on by taking my rear apron off and bolting on easily. Already have wiring plug hiding behind the bumper just want a bar. probably best you give me a call or pop in at some stage cheers Jon Quote Share this post Link to post Share on other sites
