Etwenty1 45 Report post Posted August 25, 2013 just removed a hard wired cellphone dock, cut out wiring carfully but now have no horn or sil. Fuses are intact, any ideas where to start? Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted August 25, 2013 I'll point out the obvious and say you probably cut the wrong wire or if it was sharing a power source and you have cut that out. Only way your going to fix it is by getting an e30 ETM and find the wiring diagrams then trace the wires .. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted September 23, 2013 You're right - you are pointing out the obvious the dock had wires running from the rear ashtray area back to the rear seat, thats what i cut thinking is was aftermarket wiring taking power from the battery in the boot via that route.. off to google e30 wiring diagram unless someone has committed to memory.... Quote Share this post Link to post Share on other sites
