Etwenty1 45 Report post Posted August 25, 2013 (edited) A tidy Gold PFL E30 parts as belowPrevious threadWheels - ON HOLDManual Conversion - GONESunroof Panel - GONEHeadlights - $100 $80 the pairBonnet - $45Doors less trims - $30M20 radiator with shroud - GONEManual sunroof winder complete with knob, plate and screw $50Wiper motor $40Hood cable inc handleDash (couple of cracks)Taillights $60 the pairICV $30Coil $20Windows and sunroof are manual winders, seats are ripped, door cards are a mid brown and would clean up ok.Car is in Tauranga but happy to freight. Edited September 29, 2013 by etwenty1 Quote Share this post Link to post Share on other sites
328FTW 0 Report post Posted August 26, 2013 Bonnet cable and windscreen wiper motor? Quote Share this post Link to post Share on other sites
marquis 18 Report post Posted August 26, 2013 2door or 4door sedan? Quote Share this post Link to post Share on other sites
marquis 18 Report post Posted August 26, 2013 says 4 door in titleSorry. It's a Monday. Haha Quote Share this post Link to post Share on other sites
notsteve 0 Report post Posted August 27, 2013 (edited) Instrument cluster? Gearstick boot? Edit: Also looking for the plastic demister venting pipe that is behind the instrument cluster Edited August 27, 2013 by notsteve Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted September 29, 2013 Shell will be going to scrap this week so any requests? all front end parts look good, grille set $50, 1/4 panels $75 ea , bonnet $45, valence $25, chrome bumpers $60 the pair, can pull the power steering system complete $150 including rack and pump, no visible leaks. 4 King springs, including both front struts complete with calipers. $200. 325i exhaust $100 Would rather not have to store & TM stuff. Quote Share this post Link to post Share on other sites
Tidy30 38 Report post Posted September 29, 2013 (edited) Quite an amateur question here with the King springs, but if they were into an E30 cabrio, any idea the delta height they would produce? I'm looking for some slight lowering, as the driveway to the garage is quite steep. Haven't done my research yet, but gotta start somewhere. Thanks Edited September 29, 2013 by Tidy30 Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted September 30, 2013 (edited) Quite an amateur question here with the King springs, but if they were into an E30 cabrio, any idea the delta height they would produce? I'm looking for some slight lowering, as the driveway to the garage is quite steep. Haven't done my research yet, but gotta start somewhere. Thanks I think the cabrio fronts are different to non-cabrio but someone more knowledgable might chime in? I also have a e30 Msport set of complete struts and rears. Does you car have ABS? pev thread for car http://bimmersport.co.nz/topic/33622-yet-another-e30/ Edited September 30, 2013 by etwenty1 Quote Share this post Link to post Share on other sites
forty 0 Report post Posted October 1, 2013 hey man have u got the fog lights for a pre face lift... or the plastic blanks that clip in where the fog lights would go cheers Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted October 1, 2013 hey man have u got the fog lights for a pre face lift... or the plastic blanks that clip in where the fog lights would go cheers Have definately got the blanks, think i have some fogs as well. WIll get back to you. Quote Share this post Link to post Share on other sites
Dave@nz 11 Report post Posted October 8, 2013 Hi Can you supply the rubber boots, plugs and about 500mm wiring for the fuel gauge/pump at the tank for pre face lift as seen in this link http://bimmersport.co.nz/topic/45816-e30-fuel-sender-wiring-harness-and-boot/ Cheers, Dave. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted October 8, 2013 Ill have a look if mine is the same but yes. Quote Share this post Link to post Share on other sites
APT 205 Report post Posted October 9, 2013 Have you got any floor mats? Quote Share this post Link to post Share on other sites
Brook-e30 0 Report post Posted October 9, 2013 Do you still have the front valence lip? Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted October 9, 2013 Do you still have the front valence lip? yes i still have a PFL lower lip, the black plastic part. Quote Share this post Link to post Share on other sites
