Dave@nz 11 Report post Posted August 29, 2013 Hi Guys, I would like to buy the section of wiring harness with plugs and boot that plugs on to the fuel sender unit of a pre face lift E30. The red arrow points to the type of boot required and the green points to the wiring harness and plug which I hope to replace. The missing boot form the plug and damaged casing due auto electrician “repairsâ€. Must be in good condition with boot/plug and outer black casing last two feet at least of wiring length, Please pm me with details. Thanks, Dave. E30 Sender wiring Quote Share this post Link to post Share on other sites
Dave@nz 11 Report post Posted August 31, 2013 Bump this thread still require this part. Dave. Quote Share this post Link to post Share on other sites
Dave@nz 11 Report post Posted September 19, 2013 Hi, I am still after this item, Please let me know if you can supply. Thanks, Dave. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted October 9, 2013 Yup, there is a change to the pump system - early cars (which the OP has) had a lift pump and external pump, later cars which is showin in your pic, just have an internal high-pressure pump. I'm no sparky but I think it would be a pain to change from one to the other?? Quote Share this post Link to post Share on other sites
