andrewm
e39 m62tu - extra bits after intake swap
So I did the m60 manifold with velocity stack swap and changed valve cover gaskets, ccv, ccv gasket, cleaned throttlebody changed gaskets etc however now I have put it all back together I have this rubber ring left over. Seems too chunky to be an o-ring, perhaps it goes over a cable? No part number on it and I cant for the life of me think where it came from. I also had passenger airbox off to have a look at fuses underneath.
I have just sat it on radiator shroud to give an idea of size- its about 10mm in height
1999 540i m62tu jap import automatic.
online photo sharing
Edited by andrewm
Looks like one of the rubber spacers that go on the locating pins on the under side the manifold cover.
