slybma
FS - E30 Rear disk brake setup
I have a disk brake setup for the rear of an E30, was removed for a 5 stud conversion. missing the handbrake cables as i still needed those. only after a bottle of Bourban or something for the setup.
Cool as, it's just the suspension arms, hubs, brake rotors and calipers. Should have some brake lines lying around somewhere but might want new ones and will need handbrake cables
And you'll need a bleed nipple for one of the calipers, it had snapped off in the caliper. I've drilled out and removed the rest of it ready for a new one
