Philip 0 Report post Posted December 5, 2013 Hi, My drivers window had been intermittent for the last few weeks, working somethings, not other time, then one time it came to a halt, about a quarter of the way up, and wouldn't move again. When i pressed the button i would hear 1 audible 'click' from the motor, but nothing happens then. I replaced the motor with one from the scrapyard and greased all channels, everything was free flowing. fitting everything to the door and the window went all the way up and down a few times, but would not learn where top and bottom were. after a few ups and downs the new motor stopped a quarter of the way up again, and again is dead , other that 1 click upon pressing the button. Would this issue be something else other than the motor/reg? I've swapped the switch too to no avail. any ideas on where to get a motor/reg if i require it? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 6, 2013 also check the door jam switch as these wear out and the control box wont know if you door is closed or not Quote Share this post Link to post Share on other sites
Philip 0 Report post Posted December 6, 2013 yeah had a good fiddle with that and it was no different, no movement at all Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 6, 2013 so when you push and hold the micro switch in with your hand , door is open , window should go up a bit , then use the window switch button to make it go all the way to the top, key needs to be on , when you release the micro switch the window should drop down a bit to allow the door to be opened etc. the tip of the micro switch wears down with use , compare it to the left hand side. or maybe you just got a faulty motor unit Quote Share this post Link to post Share on other sites
Philip 0 Report post Posted December 6, 2013 Possibly got another faulty motor... Just fitted a spare battery I had directly to the motor and it was the same, 1 click, and nothing else. Do you have any motors for sale?.... Which are definitely working Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 6, 2013 Possibly got another faulty motor... Just fitted a spare battery I had directly to the motor and it was the same, 1 click, and nothing else. Do you have any motors for sale?.... Which are definitely working yes [email protected] 021433600 papakura Quote Share this post Link to post Share on other sites
Philip 0 Report post Posted December 13, 2013 Got a new regulator and motor from Brent and now all sweet. Cheers Quote Share this post Link to post Share on other sites
