E46 Liam 2 Report post Posted December 9, 2013 Hi All, I have a seal on my rear diff which needs to be replaced, It is the right output seal. It is not dripping oil, but oil is defiantly seeping out. How hard is it to replace these seals? is there anything to be wary of or tricks which make the job alot easier. I have got a quote to do this work and it was Huge, so I will be carrying this work out myself over the next week or two. Just interested to see if anyone else has had to do this and what their results were. Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted December 10, 2013 (edited) Piece of piss to do ... very simple. If you know how to turn a few nuts and bolts and know how to bang in a seal then you'll be fine. You don't even need to drain the diff oil (you'll lose a little bit but not a huge amount that you can't top up later.) If that one is leaking the main seal will probably leak soon also - that one is a little more involved but not too bad (just more stuff to remove in contrast to this one which is bugger all) I did mine on jack stands without much issues. Edited December 10, 2013 by M3_Power 1 Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 10, 2013 Wicked thanks Tom, so you can replace it without removing the Diff? Jerry clayton on the shore quoted me over 600 to do this which is nuts when you consider the parts only cost about $80. Im going to get my mate to help out anyway, he's mechanic so i don't see this being a major. Thanks for the instructions too. Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted December 10, 2013 (edited) Wicked thanks Tom, so you can replace it without removing the Diff? Jerry clayton on the shore quoted me over 600 to do this which is nuts when you consider the parts only cost about $80. Im going to get my mate to help out anyway, he's mechanic so i don't see this being a major. Thanks for the instructions too. Hmmmm that quote does sound a bit more than I remembered something like this to cost. Try Peter at Team McMillan or Ray at HellBM if you don't want to get your hands dirty. Diff stays in .... If memory serves the left one you might have to remove one section of the exhaust, but the right one you should be fine with just dropping the shock. I did the whole thing on my own at home .. although I had access to the correct BMW seal insert tools which made it a bit easier. But nothing a correct sized socket can't do LOL. Just remember don't jack up your car from the diff or the diff cover - but on the jacking point on the front of the rear subframe. Here's a few photos I took of the input shaft seal (which is a lot harder to do) Edited December 10, 2013 by M3_Power 1 Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 10, 2013 I perfectly happy with dirty hands. The quote was high cause they were going to drop the diff out to change the seal. You mentioned that you have to drop the shock? Where did you undo it from? Quote Share this post Link to post Share on other sites
central3 31 Report post Posted December 10, 2013 Make sure you do not press the seal in too far - I had mine done by a dealer (input and output seals) and they pressed them in too far - major leakage - search the M3forum for more info - more info on my issue containe here http://bimmersport.co.nz/topic/37133-m3-make-over/ Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 10, 2013 Make sure you do not press the seal in too far - I had mine done by a dealer (input and output seals) and they pressed them in too far - major leakage - search the M3forum for more info - more info on my issue containe here http://bimmersport.co.nz/topic/37133-m3-make-over/ Thanks Paul, What oil did you use to Re Fill the Diff after you had changed the seals? You mentioned in your thread about subframe cracks? Where would I look when under the car to see if there is any issues on my car in terms of this? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted December 10, 2013 I perfectly happy with dirty hands. The quote was high cause they were going to drop the diff out to change the seal. You mentioned that you have to drop the shock? Where did you undo it from? No dropping of diff needed that's for sure. Just the bottom bolt from memory to allow the dummy shafts to swing down. Make sure you do not press the seal in too far - I had mine done by a dealer (input and output seals) and they pressed them in too far - major leakage - search the M3forum for more info - more info on my issue containe here http://bimmersport.co.nz/topic/37133-m3-make-over/ That's pretty useless if a dealership fitted the seals and pressed them too far ... the factory seal insert tools are basically idiot proof!! I can't see (if they have used one) how they could accidentally press them too far!! At least anyone competent enough working on it would have taken the measurement of how far it sat before pulling the old seal out (or checked the specs!!) Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 10, 2013 Can the seal insert tools be eaisly sourced? Through ebay or similar? Quote Share this post Link to post Share on other sites
central3 31 Report post Posted December 11, 2013 Thanks Paul, What oil did you use to Re Fill the Diff after you had changed the seals? You mentioned in your thread about subframe cracks? Where would I look when under the car to see if there is any issues on my car in terms of this? Not sure what oil was used - dealer did the job. Tom's your man for sub-frame cracking comment but it is the right hand rear mount area that is the problem - search M3forum for (endless) information on the subject. Can be easily inspected from under the car/in the boot - very rare problem No dropping of diff needed that's for sure. Just the bottom bolt from memory to allow the dummy shafts to swing down. That's pretty useless if a dealership fitted the seals and pressed them too far ... the factory seal insert tools are basically idiot proof!! I can't see (if they have used one) how they could accidentally press them too far!! At least anyone competent enough working on it would have taken the measurement of how far it sat before pulling the old seal out (or checked the specs!!) You are totally right Tom but to their (Jeff Gray - Palmerston) credit they drove 200km and picked up the car - trailered it to Palmy and fixed it. Especially impressive since I had removed the diff for them to do the work - I was wrapped with the service Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 21, 2013 What oil does the rear diff on an e46 m3 require? I am going to replace the seal this week and want to know what oil i should use to refill the diff? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted December 22, 2013 (edited) SAF-XJ with FM Booster BMW Part number 83 22 2 282 583 - comes in a 3 pack box (you'll need about 1.3litres - so just over 2.5 bottles). Edited December 22, 2013 by M3_Power Quote Share this post Link to post Share on other sites
E46 Liam 2 Report post Posted December 30, 2013 Thanks guy for your help, I replaced the seal on saturday without any issue, We did it at my mates workshop which made it alot easier. Hardest part of the whole operation was inserting the new seal into the diff. Checked the oil too and it was still at the full mark and very clean so there was no need to add or change it. Quote Share this post Link to post Share on other sites
earon 32 Report post Posted January 18, 2014 hey guys really sorry to hit up an old thread.. i saw tom's presence here, thought I'd best get his advice. so woke up to an slight shock this morning a slight leak on the m3's diff input shaft absolutely gutted as I've always practiced preventative maintenance and replaced parts just on an assumption of age etc etc (the m3's a late 05 CS build) haven't driven the car for 3 weeks now and this is the first time I've been caught out ..car's been absolutely pristine otherwise, drove it a lot through 2013 and it's been brilliant!! probably the best M car that's been in the family My question was while planning to do the input shaft seal, should I be looking at doing the left and right output seals?? I'll be visiting Ray from HellBM on Monday morning so I'll probably let his team handle the work, diffs are a big no no for me, I'm not keen to touch them really, engine's I don't mind pulling apart but diffs present a different obstacle haha Thanks for any input guys Quote Share this post Link to post Share on other sites
