kiwi328i 118 Report post Posted December 12, 2013 If someone has a decent one out of a car that hasn't been to the moon and back and is under $100.00 within Auckland, I will be keen. I think my car has a very worn one, doesn't like to self centre so much as lean over. It's stuffing up the alignment. I wanna have a go comparing it and replacing it to see if that makes a change. I am guessing later, and less mileage the better? Apparently they are all the same part number from what I have googled. I could be wrong. For what its worth I have a E34 1993 530i manual, I don't think it should. My car has done nearly 197k miles, and I have a feeling its the steering pump. Please text me 0211503550. I live out West Auckland closer the better obviously. Ray if you have a good one though I don't mind driving out there so much to look at the other goodies you have out Silverdale Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 12, 2013 v8 type?? or 6cyl as they are all different Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted December 13, 2013 Hi Brent, as above "E34 1993 530i manual" therefore it's a V8. But I believe a V8 powered E39 should do the trick too. As I cant really tell the wear on such an item, I would be inclined to go for the pump with the less amount of miles and from the most modern car? Cheers Quote Share this post Link to post Share on other sites
