Bonto 14 Report post Posted December 15, 2013 (edited) Hi again, I'm getting a balance and alignment done on my 525e E28 before the long drives of summer... Any set-up advice from folk out there before I take it in? It's a standard, unmodified car. Also I'm in Dunedin, any local folk have a favoured tire shop for alignment services? I've already replaced all the control-arm bushes to shut down the infamous 'shimmy' the E28s suffer from. There's still a slight hint of it at 115km/h but it feels more like a wheel balance thing. Cheers all. t Edited December 15, 2013 by Bonto Quote Share this post Link to post Share on other sites
Bonto 14 Report post Posted January 11, 2014 In case anyone is remotely interested, four new tires and alignment has transformed the car. The toe was 3 times the normal setting on both sides... Mental note - must do the basic stuff first! Also read previous mental notes. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted January 11, 2014 Apologies - I realise this is a bit late now, but perhaps it'll be useful for someone else in the future. e28 1988-1994 518/520/525/528/535 Front suspension / wheel alignment Toe-in (+) / Toe-out (-).... +2,0mm +/- 0.6 mm Camber............................ -0°20' +/- 30' Castor.............................. +8° +/- 30' (10° lock) King pin inclination........... +11°57' +/- 30' (10° lock) Rear suspension / wheel alignment Toe-in (+) / Toe-out (-).... +2.0mm +/- 0.8mm Camber............................ <unknown to me> This is all well and good, but a total of 4mm toe at the front will wear the tyres quite quickly, especially is you ever press on. 0mm toe will likely cause wandering, but trial and error shows ~1mm toe in, front and rear, seems to work very well. Quote Share this post Link to post Share on other sites
