jeff002 23 Report post Posted January 4, 2014 spend a day to find out battery drain problem.brand new battery dry in a night. problem is fuse #57.power for the stereo .anyone can tell me replace another factory stereo of after market which way better. thanks Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 4, 2014 I can't recall fuse 57 circuit offhand but quite likely more circuits on it than just the radio. I would doubt the radio itself is faulty, there are other more common issues for battery drain in the E39. I suggest getting it checked by an auto sparky Quote Share this post Link to post Share on other sites
Neal 512 Report post Posted January 4, 2014 Does it have a factory or aftermarket bluetooth system? If the tel on signal is high it make keep your stereo and amp on after the car has been turned off. Quote Share this post Link to post Share on other sites
OneStep_TwoStep 21 Report post Posted January 4, 2014 I've posted it in a previous thread before but check out the wires in the flexible hose that joins the boot lid with the car. On my old e39 there was loose wires that were shorting out and preventing the car going into sleep mode. 15 minutes with some solder and electrical tape and she was sorted. 1 Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 4, 2014 Does it have a factory or aftermarket bluetooth system? If the tel on signal is high it make keep your stereo and amp on after the car has been turned off. it use to have a phone on it and I already disconnected it. Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 4, 2014 (edited) I can't recall fuse 57 circuit offhand but quite likely more circuits on it than just the radio. I would doubt the radio itself is faulty, there are other more common issues for battery drain in the E39. I suggest getting it checked by an auto sparky #57 is the telephone,but I already disconnect the phone before I tested. Edited January 4, 2014 by e39 tour Quote Share this post Link to post Share on other sites
Neal 512 Report post Posted January 5, 2014 Try taking the plug out of the Telephone module. Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 7, 2014 Try taking the plug out of the Telephone module. where about the telephone module? Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 7, 2014 finally disconnect the telephone transmitter Quote Share this post Link to post Share on other sites
