samo455
motatronic swap help
i need some tech help
i brought what was called a complet motatronic 1.3 convertion
i am runing 1.0 at the moment
so my tps has a round 5 pin and new loom has a straght 3 pin
can i get way with changing tps or do i need a new throtle body
also injector plug dont fit becuase the rail is in the way but i can probly just mod that
tha main prob is that the ecu end of my loom has 1 three pin and 1 11pin coming from under the dash
the new loom has 1 1pin and 2 4pin conector
are there pinout swaps for thees or am i doomed once again
any help or any parts to fix would be champion thanks guys
Edited by samo455
