Ahmedsinc 414 Report post Posted February 4, 2014 How do ya open the boot on an '02 530i with a flat battery???? Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted February 4, 2014 Turn the key hard to the left? Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted February 4, 2014 Turn the key hard to the left? Lol, popped downstairs to try that right after I posted. Ta Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted February 4, 2014 ah hahahahahahahaha.................... 1 Quote Share this post Link to post Share on other sites
aja540i 1908 Report post Posted February 6, 2014 Climb inside it and pull the emergency release!! Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 6, 2014 Flat screw driver, hammer, twist, done you could even cut the screw driver down attach a handle and have a custom modded boot opening device Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted February 6, 2014 Or, open the bonnet & connect jumper leads onto the jump start posts then push the boot release button... Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 6, 2014 Nope that uses power, clearly were playing the no power allowed game coz what happens if your jumper cables are in the boot Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted February 6, 2014 I had to borrow a battery charger to hook up to the under bonnet points because i was parked against a wall and my charger was stuck in the boot. Wadnt in a rush so didnt try key trick Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted February 6, 2014 Nope that uses power, clearly were playing the no power allowed game coz what happens if your jumper cables are in the boot Well, you need another battery for a power source, so presumably the "another battery" source will have some jumper leads too... Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted February 6, 2014 You havent seen breaking bad huh? Quote Share this post Link to post Share on other sites
