Mr2low 57 Report post Posted February 13, 2014 My anycar link turned up today with the harnes that is designed to go into the radio unit behind the back seat installed as per instructions unit won't power up any one had experience with one of these Quote Share this post Link to post Share on other sites
jeffbebe 1568 Report post Posted February 13, 2014 Yep, there are two slots for the power cable plug in the harness as the CD usually runs from the rear via the radio module to the front monitor. Swap the power plug to the other slot and away you go. Had the same issue with my iPod kit. Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 14, 2014 Yeah tried both and as the plug can go in either way tried all possible options gonna take the multimeter to it tonight see if I'm getting power anywhere Quote Share this post Link to post Share on other sites
jeffbebe 1568 Report post Posted February 14, 2014 Sounds stupid but did you try pushing the plug all the way? I found on mine that if you just relied on the main harness 17pin adapter to clip everything in place it left the power plug sticking out a wee bit and it worked when pushed in a little further. Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 14, 2014 (edited) Yeah just been going over it with multimeter too only way I can get it to do anything is to change the 4 pin switches to alpine m bus then it makes my screen go white lol but the blue power light on the anycar flashes not doing that again. Lucky I have another radio module its a jap one but I'll try swapping them over tomorrow or may I need to unplug the cd changer from the back of the head unit coz it still gas power who knows it's dark and I'm being eaten alive by mozzies Edited February 14, 2014 by Mr2low Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 14, 2014 Done, swapped to the jap radio unit that was floating around in the boot worked straight away 1 Quote Share this post Link to post Share on other sites
