///MPROVD
WTB e30 astral silver front right fender/gaurd
Hey im after I tidy astral silver front right gaurd to replace a damaged one must be same colour. let me know 02102731873
Cheers.
I'm sure you know this already but you can get the same OEM coded paint and some good clearcoat both in aerosol for around $25 each from car colours in Albany. May help you if you can't find one in the right colour.
I painted the panel in my tech1 spoiler and it worked real well. Am going to do the same for the entire kit one day. Although I might buy a bottle and use the gravity gun, as using aerosol to apply clear coat is a little time consuming, relatively speaking.
Sent from my Nexus 5 using Tapatalk
Gaurd has crash damage from when I brought it not worth repairing if I have to ill get a different colour gaurd and paint it but I thought id try my luck on here first
