Ahmedsinc
FS: M52B28 rotating assembly
Crank, conrods and pistons from a M52B28TU available. With a couple of small machining jobs will be perfect for an M20 2.8 stroker build. $150 ono, or will become the column for my letterbox if unwanted :)
Photo indicative only, assembly still in block for safekeeping
Have you got everything needed to stroke an M50 to 2.8? If you do I'm keen depending on shipping cost to Napier
You'll need rods from a b20 and a b25 base engine if you don't already have one.
And a machine shop to make the crank spacer.
