nutter 1 Report post Posted May 4, 2014 (edited) Hey there Im selling the e30 M318i Manual thats beeing sitting for the last 2 years in a factory. it runs fine and shifts good, car is dereged and is the Gold/Brown colour(Pics will be up tomorrow with all KM and details) I am looking at $800 for the car or trade for a manual conversion kit for a E34 525i M50B25 i have a set of 17" Rims as well(pic will be up tomorrow) 2 tyres are ok the other 2 not so good, the rims have curbing hence the price $150 i have a 1 Clear e46 front indecator and 1 right amber one $20 each i have both E46 Front Fog lights Clear $50 each all photos will be up tomorro when i find my camera Thansk Gareth Edited May 4, 2014 by nutterbutter 1 Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted May 4, 2014 The gearbox, flywheel and starter from your E30 will all bolt up to the M50 engine. You could just use those and then youd just need a pedal box, crossmember, driveshaft and selectors to finish the conversion 1 Quote Share this post Link to post Share on other sites
nutter 1 Report post Posted May 4, 2014 The gearbox, flywheel and starter from your E30 will all bolt up to the M50 engine. You could just use those and then youd just need a pedal box, crossmember, driveshaft and selectors to finish the conversion True is there a tread up about this sorta swap? so i can try sus out what shaft,Crossmember and selector i need as Clutch line and Master and slave i can get new. thanks for that info BTW Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted May 4, 2014 You should just need a crossmember from a manual e34, the selectors might just be a different length easy enough for an engineer to change the length. Drive shaft im unsure on, again length will be different but im not sure if the output flanges are the same, could have one made from half the E30 drive shaft and half your e34 auto driveshaft easy enough. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 4, 2014 Just be aware that using a custom driveshaft will require hoops and certification, on top of the +/- $600 cost of having the shaft made by an engineer. As opposed to using unmodified OEM parts which do not require a cert. Chances are, if you can find someone with the gearbox crossmember you'll also find the right OEM driveshaft. M20 / 40 boxes will mate up to the M50 but the shifter linkages will need to be bent around a bit, otherwise your shifter will sit at an awkward angle. Plenty of info on Google listing the pros and cons of such a swap. Good luck! Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted May 5, 2014 The gearbox sits at the same angle between the M40 and M50, the swap requires a cert for swap even if you go with the OEM parts but it just makes it easier to hide with an OEM driveshaft Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted May 5, 2014 The gearbox sits at the same angle between the M40 and M50, the swap requires a cert for swap even if you go with the OEM parts but it just makes it easier to hide with an OEM driveshaft i think he was meaning if you kept same engine, it doesn't need it. i.e. my stock 325i having a manual gearbox swapped in does not require a cert you would be needing a cert for an engine conversion anyways. Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted May 5, 2014 i think he was meaning if you kept same engine, it doesn't need it. i.e. my stock 325i having a manual gearbox swapped in does not require a cert you would be needing a cert for an engine conversion anyways. Technically because he will need to replace the crossmember with one from a manual he will need a cert, unless he can mount the manual box to the auto crossmember with out altering it then a cert is needed. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 5, 2014 Hmm, all the documentation I read with regards to a manual conversion via the LVVTA site led me to believe that as long as all parts were OEM WITHOUT any modification then a cert was not required. Naturally if a custom driveshaft or modified xmember etc were necessary then certification would be needed. Plus I had a good long chat with my local WoF guy (who also builds some rather 'interesting' cars himself - 1UZFE into a WRX to name but one) and he confirmed the above as being true. That being said, I have not changed the engine from its factory equipped M50B25. Yet Yes, the gearbox does sit at the same position on the engine, but doesn't the M50 sit at a greater angle in the engine bay relative to the M40/20? Hence the need to bend the shifter linkage so the lever isn't on the pi**? Quote Share this post Link to post Share on other sites
slybma 38 Report post Posted May 5, 2014 Ya ive read the documentation online, it'd all depend on how bad of a day your wof inspector was having i wouldn't be failing it if it was all BMW manufactured bits used. Our local LVV cert guy says differently, but i think he just wants more work. The m50 and m40 angle is the same its the m20 that leans at a different angle. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 5, 2014 Ya ive read the documentation online, it'd all depend on how bad of a day your wof inspector was having i wouldn't be failing it if it was all BMW manufactured bits used. Our local LVV cert guy says differently, but i think he just wants more work. The m50 and m40 angle is the same its the m20 that leans at a different angle. Lol, things a bit slow in the HB for certifiers these days then? Ahhh, now that's making more sense. Would open up quite a few more options for gearing too! Quote Share this post Link to post Share on other sites
fhall 3 Report post Posted May 9, 2014 No cert is needed for manual conversion. When they say no modification to the gearbox gross member, they mean that the physical crossmember hasn't been cut and welded etc. Simply mounting the crossmember onto the car is not considered modification of the crossmember. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted June 8, 2014 Hey thereIm selling the e30 M318i Manual thats beeing sitting for the last 2 years in a factory. it runs fine and shifts good, car is dereged and is the Gold/Brown colour(Pics will be up tomorrow with all KM and details) I am looking at $800 for the car or trade for a manual conversion kit for a E34 525i M50B25 Did you decide to sell the 318? Thanks Ian Quote Share this post Link to post Share on other sites
